Recently I was looking for a way to mount my center channel speaker above my tv. Basically I bought a new tv stand without thinking about where the center channel speaker would go. Anyway, I found this cool little mount for a 32in tv. I had searched on line and came up with not many ideas for a good solid mount with options. This mount swivels and tilts. So really you could point you speaker anywhere. It supports up to 40lbs. and is small enough to fit a standard bookshelf style center channel or bigger up to 40lbs. I know this is after the fact, but I figured I would post it in case someone else is searching like I was. http://www.amazon.com/gp/product/B000PF74OK/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1CJCDTQ3K4MBCRTKD0A2&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
