Rickster71
Rickster71
Hello all.
I'd like to upgrade my pc speakers, to something better than my Logitech Z-540's
What are you doing for pc speakers?
I have a pretty good sound card, Creative Elite Pro, has an external console with Toslink output.
Is anyone using small bookshelves, hooked to a receiver?
Thanks
Rick
B3Nut
Small bookshelves hooked to an old stereo receiver have been my PC audio MO for a long time now, it lets me put some of the crap I've accumulated to use. :D
Home PC's: Energy Point 1e bookshelves, 1976 Sansui 6060 receiver. (speaks $9.99/ea at Goodwill, receiver $4 at St. Vinnie's, just needed a fuse.) XP PC goes to AUX, the Vista box to Tape 1. Vista PC also feeds main hi-fi in adjacent living room with WMA Lossless files.
Office PC: AR M.5 bookshelves, Onkyo TX-3000 receiver (speaks $9.99/ea and receiver $14.99 at Goodwill)
I like these setups better than regular computer speakers.
Todd in Cheesecurdistan
Soundman
Soundman
I have the Logitech Z-5500, which delivers 5.1 surround. Obviously, this is not the best thing out there, but in a small room, it sounds just fine, alot better then many of the other products out there in the PC market that are basically utter crap. The best solution is probably a receiver bookshelf combo, but this setup does a decent job for basic computer use, much better then some others i've heard in the same price range.
Clypher
I have this too. If you ask me it's the best big name set you can get. At the time I didn't think of looking into something more.
FWIW, I prefer them vastly to the Klipsch Promedia I have as well.
Edit: Once I have my new computer, and HT setup I am going to try using my TV/HT speakers for my computer. Just need to figure out a way to have a keyboard and mouse comfortably on my lap on a couch... then I can park myself for a long time.
GlocksRock
GlocksRock
I'm using Klipsh Promedia GMX-A 2.1 for my PC, and using the Promedia 2.1 THX Certified system in my bedroom as speakers for the dvd player/tv and .mp3 player. Both sound fantastic, and have excellent bass, and they can also play quite loud for their size.
