Any issue if i connect passive subwoofer to my AVR??
TLS Guy Seriously, I have no life. Mar 13, 2020 #2 vipin said: Any issue if i connect passive subwoofer to my AVR?? Click to expand... You will get no sound out of it, unless you connect a power amp between the AVR and the sub.
D drivehard Audioholic Intern Mar 13, 2020 #3 I fed the Sub RCA output of a receiver to another two channel receiver to power a pair of subs...worked just fine. OP - we need more details to answer your question.
TheWarrior Audioholic Ninja Mar 13, 2020 #4 drivehard said: I fed the Sub RCA output of a receiver to another two channel receiver to power a pair of subs...worked just fine. OP - we need more details to answer your question. Click to expand... No no! The question has been answered. It's exactly what @TLS Guy just said - the RCA out has not been amplified, therefore no sound can come from a passive (unamplified/no plate amp) subwoofer. You provided an amplifier to your subs by connecting another receiver (which contains an amp).
lovinthehd Audioholic Jedi Mar 13, 2020 #5 Generally not recommended to use an amp channel from the avr either (plus it won't be the correct channel). Something like a Crown XLS1002 perhaps for an external amp....
AcuDefTechGuy Audioholic Jedi Mar 13, 2020 #6 vipin said: Any issue if i connect passive subwoofer to my AVR?? Click to expand... You have to connect the AVR to a sub amp or some kind of amp first. Then connect the amp to the passive sub. What kind of passive sub do you have?
