passive sub woofer setup
srive
Hello experts,
I have recently bought and installed Sony STRDH770 receiver and in Sonace ceiling speakers. Current setup is TV -> Receiver -> speakers. I also wanted to add in wall sub woofer. I'm looking for passive sub so i can install in the wall. I'm thinking about buying below
https://www.amazon.com/Acoustic-Audio-Subwoofer-Amplifier-Surround/dp/B00Y3J2RU0/ref=sr_1_2?ie=UTF8&qid=1484526812&sr=8-2&keywords=in+wall+subwooferhttps://www.amazon.com/Acoustic-Audio-Subwoofer-Amplifier-Surround/dp/B00Y3J2RU0/ref=sr_1_2?ie=UTF8&qid=1484526812&sr=8-2&keywords=in+wall+subwoofer
is this supported to Sony receiver? if not can some one advise which I can buy.
if this is supported, can some one advise on how I can setup receiver/amplifier and sub. Thanks
That driver and amp both for $130? Not likely very good quality at a guess, not familiar with the brands involved. Be warned that location is critical to performance; where you want to place it may not be the best location; says it comes with full mounting instructions but doesn't provide much in the ad for any required enclosure. You would connect one of the subwoofer pre-outs on the receiver to an input on the amp...the receiver isn't suitable to provide power to a passive sub directly, tho.
srive
Thanks for the reply. Could you advise on what other options i have. I'm looking for something that goes in side the wall. Thanks.
I've never shopped for an in-wall sub, have no walls that are suitable (I would love an infinite baffle subwoofer setup, just no appropriate place to do it). I'd look through these threads to start
