I have a VMPS Original passive subwoofer with a 12 inch Megawoofer and 15 inch passive radiator. I have had a problem with the passive radiator bottoming out on low movie effects (you can Google "Bottoming a VMPS larger" for an explanation), so I decided to replace the passive radiator with a beefier one from Creative Sound Solutions (CSS). The APR 15 passive has a much greater excursion capability than my older VMPS one. Long story short, I installed the CSS unit and while everything was fabulous musically, the sub now emits a metallic clanging distortion while watching a movie with low bass effects, even at a LOW volume. It actually sounds like the washers used to add mass to the sub were rattling around in the passive radiator, which of course they weren't. I will experiment with adding more of the supplied washers for mass to see if the distortion goes away. If not, do I need to purchase the correct VMPS 15 inch PR or is there another option? Thanks in advance.
