From what it looks like with the excursion and Vas of these subs, they move a pretty good volume.  I figure going with one size bigger will do the trick and seems to be the norm.  From what I have been seeing, you get almost as good of a responce as a port, HOWEVER, with these subs having a bit higher tune (meant for a car), the box ends up being near 7.5 ft^3 and a couple 26" long 4" ports to get a tune of around 22-23 Hz.  It seems as though I can acheive close to the same tune by using about 1/3 the volume by adding a couple PR's.  There is also something intriguing about a small cube with 4 "drivers" and an amp stuffed in it.  I figure I will use the 1000w amp for this and then in the future use it for my much larger sub project, but I could toss in 100 bucks or so in PR's and maybe make something pretty interesting.
Brett
