Parasound HCA 1000A 9.5 out of 10
Status
Not open for further replies.
jinjuku
jinjuku
Moderator
Near mint condition. Great shape.
$275 shipped/insured CONUS.
Will post picks.
jinjuku
jinjuku
Moderator
Specs:
FEATURES
* Circuitry designed by John Curl
* THX Ultra-certified
* Direct Coupled -- no capacitors or inductors in signal path
* Input stage uses hand matched complementary JFETs
* 12 beta-matched 15 amp, 50 MHz bipolar output transistors
* 785VA Toroid power transformer with independent secondary windings for each channel, 40,000 µF power supply filter capacitance
* Independent power supplies for each channel
* DC Servo and relay protection circuits
* Highbias Class A/AB operation
* AC present, standby/normal, current overload indicators
* Tiffany-style RCA input jacks, loop output jacks
* 12 volt DC automatic turn-on circuitry
* Gold-plated 5 way speaker binding posts
* Custom designed removable IEC AC cord
* Rear mounted gain controls; ground lift switch
* 2 rack space height front panel
* Rack mounting adapter available
SPECIFICATIONS
* Continuous Power Output - Stereo:
125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven;
200 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
* Continuous Power Output - Mono:
400 watts RMS, 20 Hz - 20 kHz, 8 Ω
* Current Capacity:
45 amperes peak per channel
* Slew Rate:
>130 V/µsecond
* Power Bandwith:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
* Total Harmonic Distortion:
< 0.03% at full power; < 0.01 % typical levels
* IM Distortion:
< 0.03 %
* TIM:
unmeasurable
* Dynamic Headroom:
> 1.5 dB
* Interchannel Crosstalk:
> 80 dB at 1 kHz; > 60 dB at 20 kHz
* Input Sensitivity:
1 V for 28.28 V, THX Reference Level; 1.1 V for full output
* Input Impedance: 33 k Ω
* S/N Ratio: > 116 dB, full power; > 96 dB, THX Reference Level
* Damping Factor:
> 800 at 20 Hz
* Power Consumption:
500 watts
* Dimensions:
w 17 1/4" x h 3 1/2" x d 13 1/4", h 4 1/8" with feet
* Net Weight:
22 lb
jinjuku
jinjuku
Moderator
A few PICS...
K
kiwiaudionut
Would you please post a close-up photo of the rear panel?
How old is this amp and have you ever had any issues with it?
Do you have the original packaging/manuals etc? (I always find that the guy that keeps this stuff looks after things!)
jinjuku
jinjuku
Moderator
~ 7 years old. The amp runs fine. Click on the pic that I posted and you will be able to see a larger (magnified) view.
I don't have the original box. But it will be well packed for shipping (this is something I document with camera). The amp is in mint condition.
Is there anything about the back that you have a specific question on?
K
kiwiaudionut
Ok, i was able to blow up the pic. Thanks for that. I wanted to determine it was bridgeable. I'm looking for something to either drive a passive subwoofer, or the rears of a 7.1 system, so need the flexibility to use it either way.
Hmmm.........let me think about this.
So, do you have the packaging? OOPS - you answered that already - sorry !
jinjuku
jinjuku
Moderator
No, I don't have the original packaging. I ship anywhere from 3 to 8 computers/point of sale wraps a week. I have plenty of solid, quality packaging.
Status
