PARASOUND HALO A21 vs. HCA-1500A ? Need Help!!!
E
excetara2
PARASOUND Products Question? Halo Amps
Has anyone done a comparison on the difference between the sound of these two amps? I don't have a dealer in my area but can get the HCA-1500A a lot cheaper than the Halo. The specs on the Halo are a little more powerful but the designs seem really similar on each. I didn't know if they kept roughly the same design and added a little more juice. Thanks a lot for info on either.
-Jeff
E
excetara2
Anyone had any experience with either of these?
Sarius
OK, as no one else has jumped in, I got curious, as I've been eyeing the A21 and compared specs and information online.
I suspect that the HCA-1500A is in the process of being replaced by the 'New Classic' line. I can't find one for sale new online anywhere. If you look at the specs of the nearest 'New Classic' amp, you'll see that it both costs more and is a bit derated compared to the HCA, which specs out very similar to the Halo (at twice the price) with just a bit less power, as you noted.
My 'gut feeling' is that if you've got a line on a new HCA1500A, you should snap it up like a hungry hound on a pork chop. :D
