So I've finally been spending some time with my Yamaha A-S801 & Polk SDA SRS2 and it's reminded me how good the SDA SRS2 really are. These speakers always stun me, not for what they are expected to do (which is a given) but how strong they are in other areas. This is one time I'll have to
strongly disagree with TLSGuy (with all due respect), these speakers are fantastic (I could dedicate an entire thread to them). I'm not a novice and in my humble opinion they are surprisingly good. As always, I trust my ears and not the consensus of objectivists, subjectivists or "audiophiles" (regardless of what camp they fall in). I don't even fully trust graphs because they would lead me to believe that the spike in the high-end frequencies of the SDA SRS2 tweeter is similar to the spike in the Bowers & Wilkins 805D2 tweeter. As a current owner of both, I can tell you that they sound nothing alike. The tweeter is the shortfall of the SDA SRS2.
Now to the positive, to give you an idea of the SDA SRS2 presentation with intimate recordings (which is not what they're know for) they are closer to my Sennheiser HD650s than my AKG 7XX (albeit with much more to offfer than the HD650). A few years back I had them in a different room with a different amp and I didn't find the SL-2000 tweeter objectionable. In this current set-up and room I do find it objectionable, especially when the SPL increases and therein lies my problem.
I've been thinking about ordering the replacement RDO-194 tweeters which supposedly do not have that spike which I've read is in the ~12-13kHz range . In the meantime, I've been playing with the Parametric EQ in my Roon player and I'm getting close to what sounds right to me. I've been using the "High Shelf" filter. My question is, what is primary difference between the High Shelf filter and other filters available in the software?
I've only started playing with this "by ear" (or <ear
) because I have not ordered my mini dsp mic yet. So far, the High Shelf sounds best but I'm still trying to hone down the frequency and gain settings.
Also, wondering if parametric EQ (once dialed in) will be just as good as ordering the replacement tweeters since I'm really only trying to attenuate at the very top of the band.
Any thoughts or suggestions?
