Paradigm Monitor7 v6 vs JBL ES 80
U
ukrit
Hello everybody. Please help me decide what to buy between Paradigm Monitor7 v6 vs JBL ES 80 for my front speakers. For my Center,it'd be Paradigm cc-190 (if I go for Monitor 7 ) or Es 25c (if I go for ES 80).
Movie( Action mostly) 80%, Music 20%( Rock-hard rock). AVR is Onkyo 707 and the Surround speakers'd be the same brand as the Fronts.
By the way,in my country(Thailand),we don't have too many choices to choose. Thanks a lot.
GO-NAD!
GO-NAD!
IMO, the Monitor7 is a great speaker for the money. I have never heard the JBLs before, but a quick look around the web tells me they are considerably more expensive. Since I haven't heard them, I don't know if they're any better than the Paradigms. Do you intend to buy a subwoofer? If you will be using these speakers for mainly HT, you will definitely need a subwoofer in order to get the most LFE enjoyment out of action movies.
If possible, listen to them side by side - then you can decide which ones you lkie more.
