V
Vince NC
OK thanks for the help with the fabric. I picked up enough for 8 panels today. Now I have another question. How thick should I make the panels and should they all be the same or should I make them in pairs with a different thickness for different frequencies. Thanks in advance
mike c
mike c
make them all as thick as you can, no need for different thicknesses unless there's a space problem.
they should all act as broadband absorbers ... killing the highs is easy, killing the mids/bass will require thicker panels.
Glenn Kuras
Glenn Kuras
For bass trapping you want to make the panels no less then 4" thick and MAKE SURE YOU STRADDLE corners. :) As Mike pointed out you can make the early reflection panels thick, which will help a bit on the low end.
Glenn
