I believe you get the higher bit rate only when streaming from your computer and that Pandora does not support the higher bit rate via other devices. I know I've read this to be true when streaming via a Squeezebox device. I'm curious what the answer to this question is but like you I suspect you are not getting the higher bit rate. The difference in SQ is noticeable.
