PANASONIC TH50Z700 and TH50Z70
jaffa69
Anybody know the differance between these 2 models other than the £700 xtra for the Z700:confused:
Plus if you have either of these tvs are you happy with it?:)
Thanks :D
G
gedalneil
Thanks :D
I cannot convert into pounds for you, but I do know that the Z700 is worth it if you are looking for the ability for some custom settings per input. Also, the overall picture quality is said to be a bit better than the lower Panasonic models.
