Couple of issues with this review
1. The inputs are modular which in my opinion is a major feature, not a problem. You can plug in any combination you need, unlike consumer models that lock you into whatever combo they thought was most marketable.
Also, this was mentioned in the review summary but never really explained in the detail (unless i'm missing something) They do cost $75-$100 but that is nothing in the long run.
2. I have not noticed any problems with interlacing. This may be because I am running the signal from a HD comcast dvr or progressive dvd. I think most people with this display will be feeding it similarly.
3. another plus is they come with pc inputs unlike many consumer models.
In general, this display is an excelent choice for most people who are going to hook up hd receivers/dvd's. And why would you buy a hd tv if not? The lack of a tuner and speakers is also a good thing. Most built in plasma speakers are junk and if not used just take up space and look ugly. The tuner would never be used by 90% of people who would buy this tv so why pay for it.
These are exactly the same display panels as the panasonic consumer models, just with less useless junk, more flexibility, and a lower price.
Last peice of advice for anybody thinking about one of these. Look for a Panasonic dealer. These are commercial models so look for a commercial dealer, they are out there. The streeatprices.com type dealers are mainly scam artists (overcharge shipping, etc) and you can find very comparable pricing from a real dealer if you look. Look at the Panasonic site for a list of commercial dealers.
