Panasonic Tc-p54g25 help..
Y
Yamaheart
Hi guys, just completed 100 hours break-in. I tried to do some setting but could not find the WB-ADJ MENU. How do I get there. Thanks...
Y
Yamaheart
Ask umr. If you can't get a hold of him, you might try asking someone at AVS, like one of these two people (please note the warning about "default" settings, and how they are specific to your* particular set). Thread below is google search result #1:
http://www.avsforum.com/avs-vb/showthread.php?t=1289623
Thanks Jostenmeat, WOW that is crazy huh about default setting. My thing is I can't find that WB Setting, dont know if it is really worth it? Thanks...
Y
Yamaheart
I cant connect my Xbox 360 thru this Plasma via Component cables can I? Thanks
Hi Ho
Hi Ho
Sure you can. The Xbox 360 can output 1080p through component just fine and as far as I know the TV will accept it.
Y
Yamaheart
Can I turn off the 3:2 pulldown feature on my plasma?
jostenmeat
No, it's been only with the top end Pana plasmas that you can have 24p without 3:2, whether V10, VT25, etc, to the best of my knowledge.
Y
Yamaheart
Thanks man.. The reason I asked because a friend of mine loves the picture quality, black level and cleanness of the plasma, but he wanted that "soap opera effect". It is people's choice, I guess. I dont think it is possible on a plasma. Thanks..
Y
Yamaheart
Thanks, but I tried the components and the AV on this plasma but none showed up. It worked with my old LCD. Last resort is to hook up the xbox 360 thru the Receiver... Thanks...
Y
Yamaheart
I got this to work by switch the signal from my xbox to 1080i. Thanks Hi Ho...
jostenmeat
24p has nothing at all to do with the soap opera effect, which is derived from frame interpolation. You can implement FI on top of TV signals, movies, whatever. You can google FI, or you can search my posts too I suppose, I think I've talked about it like in 50 posts by now.
