The truth is, that most people cant tell the difference bettween compressed audio and the non-compressed audio. But if you know what to look for you can pick up on it. The compression removes frequencies that are alike. Parts of Cymbols and parts of a Guttar that are simular. If you look and study the compressions, you can find the week points and you can tell the difference. It takes training of the ears, but its their.
Higher frequencies of compression become less likely to hear these gaps. With 5.1 surround sound you got 5 different channels, all with seperate compression issues. When you add it all together, there are possibilities that one channel covers the areas of the rest of the areas.
Compression of audio isnt a bad thing. It is a lossly compression and you will get some problems. The higher bitrates (above 300kbps) are almost like the original (or so they say). Im not sure what the bitrates are on a HD or Blueray DVD, but I suspect they didnt change things much from DTS. Their is just no need to meet the needs of a very few people with high enough quality of equipment and the natural ability to hear it, to justify the change. So I dont expect things to get better.
Then again, does anyone need $150,000 speakers? Can you tell the difference between $150,000 speakers and $15,000 speakers? I cant tell you, cause Ive never listened to $100,000+ speakers. Ive listened to $15,000 speakers, and I can tell you that there is a difference between them and my $1200 speakers. The difference becomes minute, and though I would love to own a pair of these speakers, I cant say that the law of diminishing returns is in the favor of the millionars in this world.
