Thanks everybody for the info.I think I have made a decision on what speakers I'm getting.By the way I have
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-81TXV.The question was based on whether I would have any problems with this thing killing off a 5.1 set up of mordaunt short I was looking at.I think I'm going to end up with a 5.1 scratch and dent from EMP.I t 'll save a little cash.I hope the b-stock from them isn't too bad off.Oh and Pyrrho thanks for the links I'm kinda geeky about that stuff anyway.
If you keep the volume down, you will not overpower the speakers. I used a receiver rated at 160 watts RMS continuous per channel (an old Pioneer SX-1250) with speakers that were rated for about half that power. I used that system for more than a decade, with no problems ever. Most of my current systems involve amplification whose abilities exceed what the speaker manufacturers recommend (I have 4 systems set up in my home). I have never damaged a speaker from doing this, and I have had various systems for a few decades now.
Generally speaking, you can find out about how loud you can play a system by putting on music that is at a fairly constant level, and slowly turning up the volume until you start to hear distortion, and then turn it down until the distortion goes away, and you have found what is likely your maximum safe volume (though obviously playing it that loud all day could lead to excessive heat). Keep in mind, that does
NOT mean that you will always be safe with the volume control at that setting, because a higher input at that setting will result in the amplifier putting out more power.
But it does give you a kind of reference point, and if that is not loud enough for you, you either need more sensitive speakers, or speakers that can handle more power, or a more powerful amplifier. Or, if you are one of the many crazy people who literally listen at levels that are so loud that they do permanent damage to their hearing, you should learn to enjoy music at safe levels instead, unless you don't want this to be a lifelong hobby and would like to end your days with a hearing aid and even then not hearing well while using that aid.
