Output signal channel indicator not working
L
Laurent
Guest
Hi,
the front display of my Denon 3805 is no longer displaying the output signal channel nor the master volume indicator. Basically the righ hand side of the display is not showing anything anymore.
Is this a failure or something that I configured by mistake?
any help appreciated.
Mort Corey
If it's showing stuff on one side and not the other, it sounds like something is amiss. You can try shutting it all the way off, even unplugging it, and see if it comes back. If that fails, the only other option would be resetting the microprocessor. OTT, it's back to Denon.
Mort
L
Laurent
Guest
I have reset the the processor but it doesn't work any better so I guess I'll have to bring it back to Denon
