Outlaw Audio Products - Good Deal?
U
Unregistered
Guest
Hi - I'd like to move up from my Harmon Kardon AVR unit to separates. Right now I can get the Outlaw 7100 amp and 950 processor plus their sub for 2000. Does anyone recommend them. This seems like pretty nice stuff and a good entrance to higher end setup than I currently have. TIA Ryan
gene
gene
Audioholics Master Chief
Administrator
You may wish to hold off on the Outlaw processor. Its a bit long in the tooth and I believe they will be issuing a replacement product soon. Their amps appear to be a very good value however.
U
Unregistered
Guest
Thanks Gene! Do you have an alternate suggestion in mind?
gene
gene
Administrator
In that price range I would highly recommend using a receiver as a pre/pro such as a Yammie RX-V1500/2500 or Denon AVR-2805/3805. It is hard to beat the processing power and flexability of receivers.
