Outlaw Audio 975 Surround Sound Processor that is also a greatly-designed DAC that sounds great with hi-res music. Still under Outlaw warranty. Price is $365.
•Dolby TrueHD, Dolby Digital Plus, and Dolby Digital decoding*; DTS-HD Master Audio, DTS-HD High-Resolution Audio and DTS decoding
•Dolby Pro Logic IIz, Dolby Pro Logic IIx, and
Dolby Pro Logic II* and DTS NEO:6** processing
•All Channel Stereo
•Performance Matched Op Amps in the Critical Path
•High-Definition Video Scaling w/full Bypass
•Quadruple Crossover Control (Separate settings for Front L/R, Center, Surround L/R, Surround Back L/R)
•Lip Synch Delay
•On Screen Display (via HDMI only)
•32-Bit CS497024 Processor
•192 kHz 24-bit DAC's for all channels
•4 HDMI 1080P Inputs
•HDMI Output with ARC
•7.1 RCA pre-amp outputs
•Front height-channel outputs
•4 Digital Inputs (2 coaxial, 2 optical)
•2 Component Video Inputs
•2 Composite and 2 S-Video Inputs
•5 Analog Audio Inputs
•High performance tuner
•Direct access station tuning via remote control
•12-Volt Trigger for remote input
•Advanced LFE and Sub Level Config. Settings
•Discrete IR on/off and input commands
•Aluminum Front Panel
