MDS,
You may want to look around on other forums for some of your questions, just for the simple fact I've only had it a few days and would like to give it a thurough going over before I can give any elaborate answers. I'll try to answer some of what I do know.
1. It so far out performs any receiver I've owned, sound wise [pioneer, denon, h/k and Sony ]
2. It does not have an auto set-up feature which are usually [not always] not very accurate anyways. It does have internal test tones that I used with my rat shack spl meter and had it set-up very quickly.
3. It has exstensive bass managment for front, surround, center and surround back each can be set individually from one another.[40Hz-200Hz?]
4. Yes I believe the midnight mode is accessible from the remote. As well as switching from cinema, movie and other surround modes. It even has a bypass mode for stereo as well as seperate configuerations for dvd-A and sacd.
I will try and give more info as requested it just might take me some time to get around to all of it.
Again this 65wpc is unreal, at first I didn't think it was that loud but after turning on the spl meter and seeing it consistenly jump from 100db to around 105-6,7db [@ about 15ft ] I came to realize it's just total clean output. If you can find a better picture of the above, or at least in-large them just look at the size of the [oh whats that called] the power thingy and you'll know how 65 watts can sound so good.
Oh yea before I forget it weighs, I believe 41 pounds so it fits Buckeye's requirment
JK Buck
