I’m trying to understand the science behind an outdoor sub, which seems to have become more and more prevalent in the market over the past few years. Since you can’t pressurize an open space, how does an outdoor sub actually work? Or is it just marketing hype that is a waste of $ in real-world use?
Outdoor subs are sometimes called 'bass bins' and are horn-loaded to increase efficiency (which is related to, but not the same as sensitivity). Sealed boxes would be OK if they're in the corners of an enclosed area, but if you want output, you need horns, lots of them and lots of power. Outdoor audio applications for bass use brute force- this is no place for finesse.
However, companies like Sonance, Episode, Jamo and others have outdoor speaker systems that use an in-ground sub that works very nicely, as long as you aren't trying to recreate Woodstock. OK, bad example- the sound at Woodstock sucked but Milwaukee's Summerfest would be a better example- it was possible to hear too much bass while over 1/2 mile from shore last week when we were on a boat for the fireworks.
Don't worry about 16Hz unless you're actually trying to play synth or pipe organ music with such low frequencies- when the low E string on a bass guitar is plucked, what we hear is generally the first harmonic, at about 82Hz, not the fundamental- because of this and the fact that budgets for outdoor venues are not infinite, they usually HP the FOH sound at around 35Hz-45HZ.
