Outdoor Setup Advice Needed
stevefitz26
I currently have a Denon 2307CI for my home theater.
Speakers consist of:
(2) rear in-ceiling speakers - HD-R65
(3) front in-wall speakers - HD-W65
(1) Powered Sub - HTD Level 2
My garage has (2) in-wall speakers - HD-W65
My backyard has (4) 100W rock speakers.
My questions is this. I am not sure how I should hook up my backyard speakers. My thoughts are to add a Marine quality tuner in my outdoor kitchenb to run my outdoor rock speakers and be able to use a remote. My garage speakers will continue to run off my Denon receiver with my home theater but on the "b" speakers. Ideally I would like to have all speakers running off the same receiver with the ability to control the (3) areas independently.
Any suggestions?
Thanks in advance.
bandphan
bandphan
id run the garage off the second zone powered by the denon, then add a amplifier for zone 3 like this http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/AV-Receivers/EliteAmplifiers/ci.A-35R.Kuro?tab=B then you can have source control through the denon, and the one remote. Id suggest a universal like this http://universalremote.com/product_detail.php?model=35 (model up is color and both wife friendly) with an rf base station like this http://universalremote.com/product_detail.php?model=109 to give you freedom from pointing at the ir. You can always pick up a http://universalremote.com/product_detail.php?model=128 as a dedicated zone remote. The package would be arournd 800-900 dollars, with tremendous convience and control.
jcPanny
jcPanny
Zone speakers
I agree with the above suggestions. Any amp with 100 Watts or more that is stable into 4 ohm would work well for the outdoor speakers. Audiosource makes some inexpensive ones and the Behringer A500 is also under $200.
I have one of the URC remotes and you can get a simple setup with the RF20 remote and RF basestation for about $75.
