Are you just running a stereo audio feed? If so, you could do it with a two channel balanced configuration. I'm not sure what kind of outputs you're working with, but if they aren't balanced already, you can get a transformer to balance them. You do NOT want to run unbalanced lines lest you want tons of interference. As for the cable itself, you'll have to check the electrical codes in your area. I don't know of any direct-burial balanced cable, I would think that you can run a certain kind in conduit for outdoor runs.
