Outdoor 5.1 Speakers - Looking for advice
mfahnestock
Hey all ---
New to this forum, but I lurk a lot and have been searching all over, but really haven't found a good answer to the following situation:
I recently built a portable a home theater out on my deck. Basically, I hang a projector screen on my pergola, plug in a Mitsu HC1500 project, a Pioneer D-400V-K upconverting DVD player, and a pair of wireless AR-871 speakers. So, in a nutshell, I have something that works. While it serves the purpose, I have come to the realization that the AR-871, while providing sound, really has a poor range on lows and mids. In addition, I miss the surround effects, so with that in mind, I am trying to find a 5.1 system that would replace them.
I need to have something portable, that I can easily tear down and store away. So I would really like to avoid running a lot of wires on the deck area. I only have one electrical outlet outside, which is currently used by a surge projector for DVD and projector. My thoughts have started down the line of wireless 5.1 systems, granted I am sacrificing some quality for this type of system, but from an outdoor perspective, I don't need top quality, I just need some decent sound, with minimal setup/tear down. Would like to keep the budget reasonable (less than $500) as most of my theater has been DIY.
Been reading a lot of stuff, but really haven't seen any decent recommendations. What would you all recommend?
Rickster71
Rickster71
I wonder if this, or something like it would do the job?
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=one+speaker+surround+sound&i=065TVEE2B
I've never heard a virtual surround speaker.
Something of this type fits the bill as far as, minimal setup/tear down.
If you take it in after use, it may not need to be of the 'outdoor' variety.
Though, to get anything with decent sound, I think you'll have to run some wires and get five outdoor speakers and an outdoor sub.
Good Luck,
Rick
