So this might seem like a strange topic but I know there are several of you, with whom I have talked before, who have very experienced technical knowledge of subwoofer systems....and I need some help....
The parish where I am music director is close to the purchase of a new organ. The rep we are working with is actually an engineer and as part of saving over the subwoofer system that are sold by the organ maker---which are grossly over priced---he designs is own. To this I was very interested in learning what drivers and amplifiers he uses.....
The system he specifies is a large ported enclosure that uses two of these 15" drivers:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-469
These two drivers are driven by an O-audio 500watt Bash amp. He claims the system has flat response to 15.5hz and can produce this output to about 110dbl. Our installation will require two of these subs as it a 1,000 seat santuary...
I am a little skeptical of a 500 watt amp being able to produce that kind of output with two of those drivers no matter how efficient and/or large the cabinet design / drivers are -- or is that completely possible in proper enclosure/deisgn??
So my question to you gentlemen is....do you have any design/driver ideas that will be able to provide extreme low distortion and high-output capabilities that will be necessary in pipe-organ reproduction. Keeping in mind the intention is to build TWO of these subs to provide flat, rock-solid performance down to 16hz on full organ 32' Subbasse stop, and fill the sanctuary with authority...
Thank you for the help/ideas....
