Optoma H78DC3 Lamp Replacement
mpdillon
Hi,
I need to replace the lamp on my Optoma H78DC3. It is listed on the spec sheet as 250W UHP. When I do a google search or a cnet.com search, all the links seem to be for specific projectors with this bulb. Is a 250W UHP a standard size/configuration bulb? Or does it really vary for each projector manufacturer? What manufacturer of bulbs do you recommend and where should I buy it?
Thanks so much. I know it is a basic question and I apprecieate your help.
pat
BMXTRIX
BMXTRIX
Lamps are the scam of the industry. Almost every projector on the market requires an individually designed lamp specific to that projector. In your case, you need a Optoma BL-FU250E replacement lamp. About $400 or so for this lamp.
250W UHP is just the power rating and the technology type. 250 watts, Ultra-High Pressure. But, what you need is not a bulb, but a complete lamp assembly, which is the only way it is sold. So, you pay for it.
There are numerous places online that sell it, I would find one of the online vendors that has solid feedback and go with them.
