SDE never say never
As they say, never say never. I did say that my Optoma 30 doesn't have any screen door effect. (thank you for pointing out my error BMXTRIX) Let me clarify. Screen door effect in DLP projectors is much less pronounced than in LCD projectors in the same price range. I used the snow scenes in ICE AGE to make comparisons when I first bought the projector. The snow looked very white on DLP projectors and on LCD projectors, well I could see what looked like a fine mesh screen. At my home, I don't notice the screen door effect, and I do stare at my screen. However, I should point out, that myself and my guests are at that magic number away from the screen. My screen is almost 8 feet wide, but it is also mounted high. I have nine foot ceilings, and my viewing seats are all at the edge of the room, which is 14 x 16. All seats are further than 1.5x the screen size away and close to 2x away. I need to be a few feet away and staring to see the SDE. Problems with the lens shift actually almost disappear with the ceiling mount option, because the projector is literally upside down. The bottom of the image is almost even with the top of my ceiling. Since the image is flipped, without any odd angles, or necessity of cornerstone correction, my projector projects directly from the center top of the screen. The lens becomes much more of a problem if you lack mounting studs for your projector or screen though. Ideally, they should be lined up, so the projector is centered onto the screen. Upside down, it can shoot straight onto a ceiling mounted screen, if they didn't change the throw much from the H30 to the H31. If you can't afford 720p, keep in mind that you and your friends aren't going to be going from your 480p projector to your neighbors 720p projector to make A/B comparisons. I noticed a definite difference myself when comparing DLP to DLP with 480p specs and 720p specs, but the price was double or more. I would also strongly advise if you can to find a place you can SEE. I read so much online about projectors, but it wasn't until I took an hour and a half ride to a high end video store and could make the AB comparisons, that I was really happy with my choice. Bring movies with extremes of one color (like Ice Age) and films with high contrast colors (like The Life Aquatic) to help you compare.
