Please be patient with me....
I made yesterday's post from work and didn't have any reference material with me. Now that I've taken some time to think, look, and review I have refined my approach a bit.
It looks to me that framing over the mirror niche has excellent potential. I am now planning to use 1x4 and 2x4 framing to constuct 5 equally spaced cavities 4" deep. I would shim the 2" thick OC703 3/4" away from the glass. Then use smoothe 1/4" finish ply on the right , center, and left cavities AND 0.79% perforations on the 2 remaining cavities (= ply, perf, ply, perf, ply). If I am understanding the principles and coefficients in "the Handbook" correctly, this would (should, could ?) return a good distribution of absorbtion and liveliness to the upper front wall (and possibly some mode control in the 150 Hz range where I have the most reinforcement). (coefficients of 4" depth with 2" 703 are: ply = .28, .22, .17, .09, .10, .11 AND perf = .4, .84, .4, .16, .14, .12).
The total front wall treatment now includes floor-to-ceiling bass corner traps + "lower wall" front, center, and left channel absorbers + corner-to-corner tuned "upper wall" resonant panels.
On the rear wall, I am eliminating the rear corner traps unless there is some later proof they are needed. I believe six of the 6X4" absorbers you have suggested will provide all the lower wall treatment I need.
The rear diamonds would not be adequate at 2" thick so I will be building them 24X24X4" thick, and have to mount them flush to the wall .
Each of the side walls will use two of the 16X4" panels + four 6X4"panels. I hope this will comfortably knock down the primary speaker reflections, significantly suppress comb-filtering, and provide enough diffusion/reflection for decent spaciousness.
One question here = how much effect does vertical panel height have on performance? Most panels use legs to raise the panel up closer to center of room height. I'm planning 1' legs which will leave the panels 2'4 from the ceiling - any appreacable effect?
Finally, I will install the 4" thick clouds on the ceiling. I don't have the physical head room to suspend them down more than an inch, so I can't create the cavity you suggested. I won't be framing the clouds, instead relying on the ridgid panels to support themselves (just a poly and burlap covering all around).
Looking at the walls, ceiling, and floor seperately, I think this will put me in pretty good shape. Looking at the room, as a whole, I am feeling a bit restricted by my existing acoustical/resource realities. It sure would be interesting if I could custom build my HT from scratch.
At least I am able to "know" how nice it would be to design HT principles into a home - this is definitely a great improvement over ignorance....
Oh well.... its off to the lumber yard to buy materials and get to work on this latest plan.... TTFN.... Hermit
