Optical or analog connection?
Adam
Adam
Kurt - are you interested in multichannel audio or just stereo?
I ask because I don't think that the multichannel analog inputs will use the Audyssey equalizer settings or your receiver's bass management. I'll check the manual in a few minutes, but that was a deal breaker for me on my Pioneer 1015 and why I didn't use those multichannel inputs for DVD-Audio.
  • Like
Reactions: KEW
Adam
Adam
My suggestion would be to connect your disc player to your receiver using both an optical and analog connection. Then, see for yourself which one you prefer. Personally, I prefer the convenience of the digital connection (single cable) and the lower chance of the signal being degraded over the connection.
My guess, although I can't say for sure, is that the DACs in your disc player and in your receiver will perform similarly. I say that because they are both 192kHz/24-bit DACs and both components are of the 6001 line. Just a guess, though.
  • Like
Reactions: KEW
The signal isn't going to be "degraded" over a few feet via analog. We've been doing analog for a LOOOOOOOONG time. These two pieces of gear are likely to be similar in quality of DAC, so I would say it is a toss up, since the x-over will be handled by the receiver in both cases except when using "source direct".
  • Like
Reactions: KEW
KEW
KEW
I'll probably just stay where I am (analog connection). I don't have the digital cable and I've got plenty of other fish to fry. I mainly wanted to make sure I wasn't missing out on some clearly significant improvement.
Thanks!
