Stoner19
Stoner19
So my Sony DVD player is starting to crap out on me and I think it's time to upgrade to an upconvert DVD player of some sort. I think I have narrowed my choices down to a Sony Playstation 3 or an Oppo player. Anyone have suggestions on the quality of the PS3? I have already done some research and Oppo definitely seems to take the cake on stand-alone DVD players. The biggest benefit I see of the PS3 is the Blu-Ray capability as well as games, and it is about the same price as the top of the line Oppo player. My TV is a Sony 40" LCD HDTV 1080p, so I definitely want to get the best quality out of my standard definition DVDs as possible. The other thing would be playing burned DVDs, DivX, etc.
You guys know your stuff! Lay it on me! :D
Seth=L
Seth=L
Since the highest enchalon of Oppo DVD players only narrowly beat the PS3 in terms of scaling ability (HQV test for the Oppo was 130 while the PS3 landed at 125). The PS3 can perform as a multimedia network device, as well as supporting various media on it's own by using USB. Put that with other reasons already stated and you've got the pros for getting the PS3.
Pros for the Oppo: it's a stand alone, it has a smaller form factor, it doesn't have fan noise, it uses IR instead of bluetooth, it plays SACDs and DVD-Audio discs (the 60gb and old 80gb PS3s support SACD playback, but only 2 channel over analog and I don't believe they bitstream multichannel DSD but they might do 5.1 LPCM). My roommate's PS3, which has been cared for very well, has broken down twice while under warranty. The first time it went down it was the drive motor that actually spins the disc. The second time it broke down it was the diode. However my older and more beat up PS3 (purchased used) has yet to have any problems. I do believe there was a bad batch of 40gb PS3s that happened to be prone to issues. Hopefully those issues have been resolved in more recent versions (80gb and 160gb).
My personal choice is the PS3, as I have no concern for aesthetics and the SixAxis controller is easy enough to use as a Blu-ray controller for myself, but note that you can purchase a Bluetooth Blu-ray remote control for the PS3. I also don't care about SACD, DVD-Audio, or multichannel analog output. I also like to play some, about 2, games. I also have no desire to search for an Oppo in a store (I don't believe in store in my local area carries Oppo) and I don't like buying things online. Picking up the PS3 is fast and easy.
I am not sure any stores carry Oppo. You buy direct from them.
Oppo has a Blu-ray player coming sometime in the next month though it is going to be a bit more than the PS3 as far as we can tell. One major difference would be multichannel analog outs if you need them - if your receiver doesn't have HDMI, then you will most likely be interested in this aspect, something the PS3 does not have.
To me what it comes down to, is if you are looking for a unit that does much more than just movies, then the PS3 is the way to go. If you aren't then I'd be looking at Oppo seriously (upscaling or BD). I would likely go with a BD player period over just an upscaling player at this point as well, so if the forthcoming Oppo BD player is more than you are looking for, those from Sony, Panasonic and others might fit the bill. All of the BD players will upscale your current DVDs, some better than others, but once you start watching the better quality Blu's out there, I don't think you will be watching too many SD DVDs.
Reorx
doh! j_garcia beat me to the punch.
Oppo BDP-83 Blu-ray Disc Player. Link
I was in the same situation a 6-9mo ago. I went and bought a $50 Philips to tide me over until the Oppo player comes out. m/n DVP5982. It's a decent upscaler...and also plays all the divx I've thrown at it. It performs better then my neighbors PS3 when it comes to divx, and burned disk compatibility.
I also have a bunch of DVD-audio disks, and no faith in any Sony products.
Reorx
mperfct
mperfct
The new Oppo Blu-ray player should smoke the PS3 in BR and SD performance. What you don't get is the aforementioned media center and gaming capabilities.
OR you could buy a Oppo 981 and then buy a Panny BD35 and be set for about the same price if you don't want to wait.
jamie2112
I will be buying the Oppo when it comes out. I have been waiting for this and is only a short time away.....sweet:D
Pyrrho
Pyrrho
The Oppo DV-983H is also easy to make region free, and can convert between PAL and NTSC (and upscale both to HD formats without loss in picture detail in the conversion process), so one can play DVDs from anywhere in the world. Can the Sony be made region free, and can it convert between PAL and NTSC?
The Oppo also is great for automatically scaling things to keep the aspect ratio correct and uncropped, if one chooses the correct settings in the setup menu. I have no idea about the Sony for that either, because I own the Oppo DV-983H and do not own the Sony.
I have hundreds of DVDs, and I want them to look their best, so I got the Oppo DV-983H when it first came out. It is a great player, but I can certainly understand someone thinking that it is pricey for a DVD player. But nothing less expensive is as good.
If you can wait a couple of months, you might want to see how the new Oppo Blu-Ray player is rated after it comes out.
Another thing to consider is the upconverting capabilities in one's receiver, video processor, or TV. If one has state of the art capabilities in any of those, then getting the Oppo DV-980H would be great to use with one's setup, and just set it to output what is on the disc (i.e., not upconverting at all in the player).
In fact, this is something quite annoying, as one tends to pay for upconverters in one's TV, receiver, and DVD player, and you only will be actually using one of them for a particular source. So typically, one's money is wasted somewhere in this. The same applies to DACs (both audio and video). I just use the HDMI output on my Oppo, so the money spent on its audio and video DACs is wasted in my case.
