W
wally09
I need help with my OPPO DVD. I have the Oppo 970HD dvd player and the video comes out very pink. I have the video setup on RGB. I cannot figure out how to get a good picture. Please help. thanks
GlocksRock
GlocksRock
by RGB, do you mean component cables? If you have the component cables hooked up, then the pink you see may be a result of the cables either not being plugged in tight enough, or you may have the blue and green wires switched. If that's not it, then I would suggest connecting it to a differnt tv to see if you get the same problem.
