1khpsupra
4806 arrived yesterday evening and I made it through the Auto adjustments. First connection was my oppo, using the supplied dv-hdmi cable.
Selected DVD / HDMI 1 and Opti 1 / sound Input. Video passes through and plays but all the video is mostly awash with green. I called oppo today and was told possibly the HDCP was causing the color shift. I asked if I should get a DVI-DVI cable and try that and he said it would be preferable.
1. Has anyone used the Oppo through an HDMI receiver w/o colorshift?
2. Could the DVI to HDMI cause a problem with HDCP?
Both units support HDCP.
3. 4806 appears to have a component to rgb conversation in the OSD, I have not tried changing this but not even sure if this effects the HDMI. Appears to be only RGB per Manual:
Manual Page 99
When connecting to an HDCP compatible monitor equipped
with DVI-D terminal using an HDMI/DVI-D converter cable,
the signals are output in RGB format, regardless of the
“Color Space” setting.
Any help would be appreciated or even feedback that have had similar problems.
Thank you
Jason
Manual Page 99
Thank you
Jason
