he guys..looking for a few user opinions on the Oppo DVD players.
I currently have a Denon 2910 DVD player and more and more, I am finding certain discs I burn aren't playing on it. It's not the DVDs as I ordered Taiyo Yuden directly, I burn at slow speeds on my LG burner, use the best decrypting software, DVD Fab Dycrypter Platinum.
Every disc I burn, including AVIs, downloaded movies, MP3s burned to DVD, play on my Yamaha DVD 657 in my bedroom. Never had one that won't play,but it does not upconvert nor has HDMI, hence the reason it is in the bedroom with my Sony Trinitron tube TV.
As I think the Denon 2910 does a great job on playing what it can, my question is about Oppo compatibility with burned discs.
Those with an Oppo player, what are your experiences? Thanks. i am considering getting their top model to run side by side with my 2910. I read the picture quality is close to the Denon anyways.  I need to know if it's worth it as I need something that will play everything you throw at it.  For example, Mp3's burned to a DVD don't play on most DVD players. How about the Oppo? Does it play AVI's or do you have to convert them, hence losing more quality. DivX?
I am losing faith in my Denon. Like I said, great for it's limitations..it is in fact three year old technology.
Thanks!
P.S. Post # 666!!!
JC
