Oppo BDP-83 Bass Management Broken
Affejunge
So I have owned my BDP-83 for a little over 2 weeks now. Overall, the reviews are correct, this is an amazing universal player. I have used it on DVD, CD, BD, SACD, DVD-A, and mkv files via the USB stick.
Everything works flawless...well almost:
I just want to let people know that the 83 will not pass the 0.1 signal to the mains if you have it set up as a 5.0 system. Here is the quote from Oppo:
LFE redirection is not a part of the software suite of the BDP-83. This is something we are requesting from the engineers, but have not enabled in our product at this time. Unfortuantely we do not have an estimated time of release for a firmware which will allow for LFE redirecting.
I am stunned. This seems such a basic feature of BM, I cannot believe it is broken. Since music is most important to me sonically this is not a huge loss (Many of my SACD, DVD-A are 2.0 or 5.0).
I am not trying to take away from this player, it is truly amazing. I have no doubt Oppo will fix this issue some time in the future. But, just an FYI if you intend to have the Oppo to bass management.
gene
gene
Audioholics Master Chief
Administrator
This is a problem with most multi channel equipment. If you recombine the LFE bass into the main channels, it can overload those channels. The newer Dolby spec mandates this I believe. Even when bass from LFE is recombined into the mains, its done at a reduced level. I first experienced this going from a Yamaha DSPA-3090 to a DSP-A1. The latter followed the newer Dolby spec.
Honestly if you're running multi channel, get a sub!
