OPPO A103 wireless adapter
rsklotz
My OPPO A103 wireless adapter died and OPPO no longer supplies replacements.
Any other source for this item?
What other none-OPPO wireless adapters will work?
BMXTRIX
BMXTRIX
You should be able to use any wireless bridge product and just plug into the Ethernet port on the back of your Oppo. I'm not really sharp with wireless bridges, but something like this should do it:
https://www.amazon.com/TP-Link-Wireless-300Mbps-Repeater-TL-WA801ND/dp/B004UBU8IE/ref=sr_1_4?ie=UTF8&qid=1531418911&sr=8-4&keywords=wireless+bridges&dpID=31Iu57JEgjL&preST=_SX300_QL70_&dpSrc=srch
Application 3 in the diagram shows wireless bridge mode, where the TP-Link connects wirelessly to your network, and the Oppo would plug directly into the bridge. You could even drop a network switch onto the TP-Link and connect all the devices in your rack to the TP-Link this way (or you should be able to).
aps7kk
Interestingly enough i just discovered my oppo wireless adapter died today. I now use a power line internet adapter instead of wireless
I would be very nervous about that. You are one blocking cap failure away from a massive disaster. I would NEVER trust one of those.
little wing
little wing
I'll second that. I tried one and got loud puts through my system at various times. I promptly removed it.
