Well, I received my new Oppo 981 a couple days ago, and am absolutely floored by the picture quality.  Absolutely gorgeous, even on low-res DivX files.
My question has to do with the analog audio outputs.  Has anyone else noticed the incredibly low bass output?  I just popped DVE into the player to calibrate sub levels for digital and then analog out.  In order to hit the same SPL as the digital out, I had to increase the sub level by twenty (20) decibels for the analog out!
I checked my connections, and everything is connected properly.  The cables are snug in their respective slots, nothing's loose.  I went through the menu to double-check that too.  Downmix is to 5.1, all speakers to small, sub to on, distances double-checked.  I can't think of anything else to check.
Has anyone else found that their Oppo 981HD has very low bass output?
cheers,
supervij
