Opinons Wanted On Acoustic Research A/v Cables
2
2891966
What Do You Guys Think Of The General Quality Of Acoustic Research Cables?
farscaper
farscaper
If you mean the ones sold at Radio Shack or The Source (up here in Canada). Then yes. Most of my cables are AR. No issues. Got them at good prices. Haven't tried their HDMI or DVI cables.
If you don't keep playing with your cables after they are installed,;) they are fine. Buy more software:D
L
Leprkon
The AR blue cords they sell at BB are decent, at least as good as the Monster that BB also sells.
The Acoustic Research Pro Series 2 (dirt cheap at Accessories for Less) are much better built. I recently put in a set of these on both of my DVD audio lines (12 cables all told) as well as a Toslink cable and have been very impressed.
supervij
supervij
Most of my cables are from Acoustic Research. They sound terrific to me. No complaints here, and I the price is right.
cheers,
supervij
Jack Hammer
Jack Hammer
Thumbs up
Most of my cables are Accoustic Research Pro Series II. They are fine, I'm very pleased with them. Don't buy them in a store they charge too much. I bought most of mine from Accessories 4Less at a much better price.
Jack
2
2891966
Thanks for the opinions I've heard no complaints and I see that the prices are great compaired to Monster cable. And they look like the quality is jjust as good as Monster also. I just order my first AR cable which is the AR MS252 I compaired it to the Monster cable with the same features. Monster was $150 compaired to the AR MS252 $42 at buy.com. I'm going to check out accessories4less. So thanks for your opinion and I'll see how they help the sound.
Z
zumbo
Not going to help the sound.:rolleyes:
AR PROII are very nice.
K
kaiser_soze
Which type of cable?
Are you asking about speaker cable or line-level interconnects with RCA plugs at the ends? If by chance you are talking about line-level stuff, then I'll share one experience. When the outer part of the plug, which is electrically connected to the shield of the cable, is plated with gold, you expect that it is electro-plated onto high-tensile spring steel. But you can't really be sure unles you take a small pair of pliers and try to bend the outer connector. If it breaks or seems soft, it is made of plastic or cheap pot metal and in the case of plastic, the gold plating is actually paint. If it is difficult to bend but gives and then doesn't return to its orginal shape, it is probably metal and may be electroplated, but it is still inferior to quality steel that has been electroplated. I had several of those cables from Radio Shack, the more expensive ones with the fat rubbery cables and the large plugs that look well made, and used them in a car application, which required some re-work a few years later. After pulling and pushing them a few times, some of the sections of the outer conductors broke away, revealing that the connectors were made of inferior metal.
bru87tr
bru87tr
you def cant go wrong for the money! I have alot of Audio AR stuff. got most of it on ebay for next to nothing. but I do own some decent belden/canare cables made by a buddy of mine for component video and they are very nice!!!!
