I was just hoping I could get a few opinions on connections for my home theater set up.
When our home was being built it was pre-wired with 14 gauge cable 5.1 surround and then terminated with a 5.1 female banana jack wall plate where all of my HT gear (preamp processor, DVD player) will be installed in a media niche/alcove. The other end of the speaker cables come to another female banana jack wall plate as well (I have some on-wall speakers from Vienna Acoustics I will be using).
It looks really clean, but my main concern is that with all these jacks/plugs … is it still an optimal set up or will there be a lot of degradation of the sound because it is passing through all these terminals?
I will be using banana plugs and cables from the media alcove to the amp and then banana plugs and cables from the wall to my speakers which also accept banana plugs. All in all (from the amp to the wall, from the wall to each speaker) it will have to cross through 4 sets of banana plugs and jacks before it finally reaches the speaker. Will this cause any loss from crossing all of these plugs?
Just in case, here is a list of my HT gear:
Speakers:
Vienna Acoustics Schonberg Series – Webern on wall speakers for the L/C/R
Vienna Acoustics Schonberg Series – Berg for the Rear Surrounds
Vienna Acoustics Schonberg Series – Subson subwoofer
HT Audio/Video Equipment:
B&K Reference 50 s2 preamp
B&K Reference 125.7 s2
Sony PS2 (for the DVD for now)
Mitsubishi WD-62825 : 62"
Cables:
In Wall Speaker Cables - 14 gauge in wall construction quality.
For the out of wall application I will most likely make my own 14 gauge cables as well, it just makes since that if the cables in the wall are already 14 gauge, then it wouldn’t be much of a benefit to go with anything other than a high quality cable of the same gauge.
Audio/Video Cables:
All of my Component/HDMI/Optical and Balanced XLR’s are through Monster THX (I know you guys aren’t big fans of Monster
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, but most of them were thrown in when I bought the equipment which saved me a few hundred bucks so I will have to stick with these guys for now.
So what do you think ... keep the clean look of the banana wall plate jacks or pull the wall plates off and connect the speaker cables directly to the speakers and amp?
Thanks in advance for your input it is really appreciated!
