The side speaker placement appears to be incorrect. IMO, this needs to be corrected before anything else. From the
THX website,
THX 7.1 placement:
Dolby TrueHD and DTS MA placement:
Notice that in both cases the side speakers are
slightly behind the point representing the main listening position while you setup seems to have them ahead!!!
NOTE: Goes without saying, once the speakers have been rearranged, any previous calibration is defunct. So, rerun auto setup and tweak all parameters again.
The question on placement of diffusers is a really good one and my instinct tells me, this is a very difficult to answer with a simple yes/no. Unless your room sounds dead, you should not need diffusers. Adding a carefully balanced mix of absorbers and diffusers will give you the biggest sound stage, best imaging and flattest FR. I suggest, put them in the locations you indicated and do objective (FR plots) and subjective (changes in imaging and sound stage) evaluations. Typically I have seen,
Absorbers – Room corners and wall intersections (for Bass Traps) and First Reflection points for mains (typically for point immediately behind front speakers and point on side wall in direction of main listening position)
Diffusers – Ceiling (between main listening position and line connecting main speakers) and First Reflection points
