Hey all, was thinking about buying a pair of La Scalas (AL5) for my 2-channel and HT. Attaching a pic of my listening area. It's about 17' wide and no corners. Side walls are another 11' out on either side. The seating is about 14.5' away from the front wall. The back wall has varied distances but the shortest distance is about 22.5' from the front wall. The ceiling has acoustic tiles and is a little under 8' high. Carpet and thick pad on the floor, the couch on the right will be removed.
Anyway, wondering if you think the La Scalas would fit my area or would it be a bad mix. In the picture I'm attaching I'll probably move the equipment rack to be on the inside to the speakers.
