Oops! lost my NAD remote. :(
Rock&Roll Ninja
Rock&Roll Ninja
Well, I lost the remote to my NAD c370 integrated amp.
I don't suspect NAD keeps a stock of them, especially since they've replaced the model (mines from 2000). And Ebay hasn't had just the remote listed.
Does anybody know a universal remote that will work with my c370 and maintain functionality? Preferably for under $100.
Thanks.
Hi Ho
Hi Ho
I did the Test Drive on the Harmony site and it has the NAD C370 in its database. You can find some Harmony models for less than $100.
Harmony 688 (I own this one and absolutely love it)
Harmony 520
Harmony 628
All Harmony remotes, regardless of the model, use the same IR database so any model will control your NAD and every other component you own.
JaceTheAce
You might be able to try eBay for your NAD remote.
