Onyko tx-ds787, my best option for about $200-$250?
bennyk
Hi, I am going to upgrade my receiver. I currently have an old Technics receiver from 1995. It has 4 channels. Front Left, Front Right, Center, and Rear (rear being 1 channel). Anyways, I want a 5.1, 6.1, or 7.1 receiver. I am able to buy a used Onkyo TX-DS787 from a family member. It is in great condition, and nothing is wrong with it. We have not settled on a price but I think it will be around $200-$250. My question is, is this my best option in my budget price range? I can't go over $300 due to my WAF (actually $300 would be pushing it). Is there something better for me in this price range? I do not need HDMI as my 57" Rear projection HDTV only has component ins and outs. I will use it mainly for movies and a little bit of music. It is a small living room that this will be in. I currently have a pair of Cerwin Vega RE-25's, a JBL N1 CC speaker, and rear Paradigm Titans. Here are some specs of the Onkyo. Let me know your thoughts and thanks in advance!
Key Features
Type Receiver
Number of Channels 6.1 Channels
Stereo Mode Power 100 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.08%
Surround Mode Power 100 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.08%
Surround Sound Dolby Digital® • DTS® • THX EX®
THX Certification Select
DSP
DSP Modes Enhanced • Mono Movie
Inputs / Outputs
Rear Input Connectors RCA (2 Audio Channels) x 7 • Digital Coaxial x 2 • Digital Optical x 2 • Composite (Video) x 4 • S-Video x 4 • Component x 2
Rear Output Connectors Digital Optical x 1 • Composite (Video) x 3 • S-Video x 3 • Component x 1
Front A/V Connections Composite x 1 • Couple RCA Jack x 1 • Headphones x 1 • S-Video x 1
Surround Analog Inputs 7.1 Channels x 1
Preamp Outputs 7.1 Channels
Convenience
Number of Zones 2
Speaker Impedance 6 Ohm
Tuner Presets 40 Channels
Tone Controls Bass & Treble
On Screen Display With OSD
Remote Control
Remote Control Type Learning
Illuminated Remote Illuminated
Design Keypad with Display
Dimensions
Width 17.13 in.
Depth 17.81 in.
Height 6.88 in.
Weight 36.6 lb.
Warranty
Warranty 2 Years
Miscellaneous
Included Accessories AA Batteries x 2 • AM Loop Antenna • FM Wire Antenna • Remote Control
Power Consumption 440 Watt
MPN tx-ds787
Product ID 7630
Release Date October, 2000
