www said:
I've been using an old Sony Receiver, STR-D611, with two micro satellites and a Micro 11 Sub, and have recently bought Infinity Beta 40 mains and a Beta C250 center. These I connected with the existing satellites and passive sub to the Sony. Yesterday I ordered a refurbished Onkyo TX-SR703 Receiver from Ubid and wonder if I can use the Micro 11 sub with it all. From reading the forum I gather that my old sub that takes bare wire or bannana connectors and isn't powered, can't work with the Onkyo. Is this true or is it a bad idea to use it even if it does work?
You should have speaker inputs and outputs on the rear of your passive sub. Take the speaker wires from the receiver for the front left and right, and run them to the passive subwoofer "in."
Next, take the speaker wires you would normally run from your front speakers to the receiver, and route them from the passive subwoofer "out" to the front left and right speakers.
The only other thing you'll need to do is run through your on screen setup display on your Onkyo, and select "no" for subwoofer or LFE channel. You need to disable the circuit for a powered subwoofer which tells the rest of your speakers to follow the receivers internal crossover.
Your passive subwoofer has the necessary crossovers to direct all bass to the sub driver, and the full signal should go to the front left and right speakers, as well as any other surround/center speakers you have connected.
