Raja262528
Hi
My name is Raja , recently I bought a onkyo tx sr 501 AV receiver, I am already done all speakers connections. Sound was amazing. But what I am facing when I increase my sound above 45% it will getting auto off. Now what can I do? How to enjoy this awesome sound with high volume...
Please help me!!!!
L
Leemix
Is it well ventilated? Hot?
Have you checked the speaker cables, are they undamaged? Any stray strands poking around behind the speaker or AVR terminals?
M Code
M Code
As posted above...
Do U have the 4-5" free-air clearance for the L/R sides and top cover as recommended by Onkyo?. A couple other points to consider if the receiver is shutting down @ high volume levels..
  • Room size
  • Loudspeaker specs for sensitivity & impedance
  • Type of source played when shutdown occurs, compressed or uncompressed stream
  • Distance from loudspeaker to listener position
  • Double check the loudspeaker wiring to eliminate any possible short circuit
Just my $0.02... ;)
