Buckeyefan 1
Buckeyefan 1
Onkyo TX-NR 801 $469
Great deal here if you need power, but not HDMI.
This is what I like about the Onkyo's.
Onkyo's exclusive Net-Tune™ protocol lets you integrate the TX-NR801 with your PC and your broadband modem via an Ethernet network. Then, no matter where your computer is in your home, it can function as a component in your A/V system. You'll find that the 'NR801 really makes the most of the MP3, WAV, and WMA files on your hard drive. It's got built-in decoding for all three formats, and you can browse and select from the contents of your hard drive via an interactive display on your TV (requires TV with direct video input), or even on the 'NR801's front-panel LCD window. If you've got broadband internet access and a router, you can also use the TX-NR801 to tune in an incredible array of Internet radio stations — you don't even need to turn on your computer to do it! 30 Internet radio station presets give you fingertip access to your favorites.
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10573582&uwb=uwba68571
