After much hunting, I ended up with a pair of Ascend Acoustics CBM-170 SE's used off Audiogon. Now I'm trying to find a good amp to power them. I was looking at an Emotiva UPA-2. The XPA-2 looks awesome, but I'm living in a tiny apartment right now, so I think the smaller one would be more appropriate. I made an offer on one on Audiogon, but if it falls through, I think I'll buy a DTA 100A and an HT SUB-100.
Earlier today a friend randomly offered me an Onkyo TX-4500 receiver that she doesn't want. I told her I'd go home and research it a little, and from what I've read it seems like it could be a decent piece of hardware. I do have a couple questions, though;
1. A receiver is what? A device that can receive a radio signal? Also, some receivers have amps built in?
The manual for the TX-4500 says:
65 watts per channel, min. RMS, at 4 ohms both channels driven from 20 Hz to 20 kHz, with no more than 0.1% total harmonic distortion. 55 watts per channel, min. RMS, at 8 ohms both channels driven, from 20 Hz to 20 kHz, with no more than 0.1% total harmonic distortion.
75 watts per channel, min. RMS, at 4 ohms both channels driven 1 kHz, 0.1% THD.
60 watts per channel, min RMS, at 8 ohms, both channels driven, 1 kHz,
0.1% THD
0.1% at rated power
0.08% at 1 watts output
0.3% at rated power
0.1% at 1 watts output
50 (8 ohms 1 kHz 10 watts)
15-30,000 Hz (± 1 dB)
2-80,000 Hz (±1 dB at main amplifier)
I understand almost none of this ^
Which brings me to my next question...
2. How can something be rated for 4 ohms and 8 ohms at the same time? Does the receiver/amp somehow know how many ohms the speakers want or will I blow something up if I plug a 4 ohm device into 8 ohm speakers? The CBM-170 SE's I have want a minimum of 25 watts at 8 ohms. Would this receiver be good and/or appropriate to power them?
3. For Inputs is says:
phono 1 & 2, tape play 1, 2 & 3, dolby in, main in FM and AM antenna.
So, are the phono and tape inputs just a bunch of RCA in's? Is there some difference between the types of audio inputs?
Will all of my music suddenly sound like it's from the 70's if I use this receiver?
