Onkyo SR 606 and Samsung UN 55B8000 problem!!
O
olivia
I have an Onkyo SR 606 and recently bought the Samsung UN 55B8000, I have connected them via HDMI, I also have a PS3 connected to the receiver via HDMI cable, and an HD/DVR cable box connected to the receiver also via HDMI, finally I have a component connected ipod dock. I had this same set up with my past with my previous TV (sharp aquos) and it worked fine. Ever since I got the new TV I have had problems where there is "no signal" coming from the cable or the PS3. When I hook these up individually via the same HDMI cables to the TV there is no problem. I have assigned and reassigned the inputs and this hasn't solved the problem. Sometime if I leave the cable box and TV on after about 15-30 mins it finds a signal. I've replaced the cable box several times and this hasn't helped. The ipod dock connected via component cables works fine. I've replaced the HDMI cables and this hasn't helped. Sometimes I turn the system on and everything works perfectly and nothing has changed. Is there some inherent incompatibility problem?? neither Samsung nor Onkyo have been very helpful and now I'm out lotsa $$ and have a system that doesn't really work!! Help!:mad:
That is a strange one.
Clearly this is a problem with DRM, specifically a problem with the HDMI/HDCP codes.
Your system ought to work, but unfortunately we get cases where it does not.
Now, a TV is an end device and only has to make one handshake. A receiver on the other hand receives and transmits HDMI and has to make continuous repeater hand shakes.
One of your units, I suspect the receiver has out of date architecture.
Make sure your receiver and TV have the latest firmware updates. If that does not work, exchange your TV as that is the newest unit. If that does not work, you likely will have to update your receiver.
This whole issue still stops people enjoying what they paid for. Congress needs to ban DRM schemes so everything is reliably plug and play.
lsiberian
lsiberian
I've found HDMI handshake with cable boxes is an uphill battle. So much so I switched to component and optical for the tuner box I have.
