Onkyo RZ70 THX ref vol level.
paulwgraber
I accidently was sitting on my remote, no sound was playing, and my volume went past 82. When it was at 82 I noticed right at 82 it said THX reference. 82 would be ridiculously loud to listen to anything. Just curious what that is, THX ref volume at 82.
Trebdp83
The 82 Absolute value is the equivalent of the 0 Relative value. They coincide with the THX Reference level. You can select one or the other for display.
As THX puts it:
"THX Certified Audio products are designed to let you experience movies the way they were meant to be heard. On every THX Certified AV Receiver the “0” on the volume dial represents THX Reference Level, the exact volume level used by the moviemakers and sound artists in the studio.
For manufacturing receivers and speakers, achieving the THX Reference Level is no simple task. It requires a tremendous amount of power to drive an audio system effortlessly without clipping or distorting. To ensure the audio products reach this peak performance THX developed a set of standards as part of its THX Dominus, THX Ultra, THX Select and Integrated System certifications.
  • Experience Studio Clarity: THX Certified Receivers reproduce studio Reference Level, 85dB SPL with 20dB of headroom.
  • Reference Level for your Room: THX Dominus, THX Ultra, THX Select, and THX I/S certification categories deliver Reference Level performance in your specific room size.
  • Distortion-free Playback: THX Certified Receivers and speakers are designed to recreate Reference Level with minimal distortion."
