The M504 being just an amp, it isn't supposed to do signal processing such as handling the crossover to the sub. If you have a pre/pro, then there should be a sub out from that. If not though, then likely your sub has either high level or low level inputs and outputs (many subs have both) so you can run your wires directly to the sub and the sub's internal crossover can handle the transition between the sub and your main speakers.
